No VTEC
Old Mar 16, 2021 | 06:41 AM
brandon.s2k's Avatar
Originally Posted by windhund116
Are you running a stock setup? Have you modified anything on the engine or exhaust? Running new spark plugs?
And yes I put in all new ngk spark plugs three weeks ago.
Old Mar 16, 2021 | 08:38 AM
windhund116's Avatar
Originally Posted by brandon.s2k
Everything is stock, just an intake and an invidia n1 exhaust.
Did the car work fine at one time, with these modifications?
Old Mar 16, 2021 | 08:41 AM
Yes it's been 3 years if not more with the same mods.
Old Mar 16, 2021 | 10:52 AM
Slowcrash_101's Avatar
I would compression/leak down.
Old Mar 16, 2021 | 01:14 PM
honda Marty's Avatar
Those codes have to do with the mss airflow sensor. When the cat is plugged the air flow is all wrong. You will get a standing air wave that acts like a valve that open and closes erratically causing major drivability issues. Try pulling out the front oxygen sensor. That will reduce the back pressure in the exhaust system enough not see if that changes the nature of the problem. It's free , just maybe some skinned knuckles.
Old Mar 16, 2021 | 02:15 PM
Does the S2000 have a MAF? I thought everything was controlled via the MAP sensor.
Old Mar 16, 2021 | 03:05 PM
engifineer's Avatar
Duh... you are correct Disregard that comment as I apparently was not thinking there I have 4 cars, 3 of which have MAF sensors!
So to bring it back to the RIGHT vehicle, I should say to address the rich running condition first as that is where the codes start showing up. P0172 and P0170 are both popping up for him per this and his first thread about his issues.
mark_k
May 28, 2018 05:13 AM
mark_k
May 28, 2018 02:20 AM
s2kldk
Apr 4, 2016 07:43 PM
