No VTEC
Old Jun 27, 2012 | 08:39 AM
grays2k123's Avatar
Default No VTEC
i have a 2003 s2000, when i first bought the car vtec was working but the vehicle seemed a tad sluggish compared to another stock s2000, since then it has stopped working. Things i have checked are: oil is new and full, air filter is brand new, vtec solenoid resistance check showed 14ohms, took solenoid off and inspected the screen which was clean with no clogging, pushed the vtec solenoid down to check for movement and checked out fine, swapped my vtec solenoid with another solenoid which was working properly on another s2000 ,lastly i used a quick splice on the vtec wire directly out of the ecu and hooked it up right at the solenoid. I have an aem ems on the car so oil pressure shouldn't matter since the standalone doesn't use that sensor. Any suggestions??
Old Jun 27, 2012 | 08:53 AM
grays2k123's Avatar
also did a compression test and was roughly 220 across all four cylinders and that was without wot so the numbers read a tad lower than they actually are. IM STUMPED
Old Jun 27, 2012 | 01:32 PM
franky's Avatar
so it's not stock? it's got to be your tuner. Vtec needs to have oil pressure in order to work.
Old Jun 27, 2012 | 09:12 PM
grays2k123's Avatar
aem does not use the oil pressure to engage vtec, so thats not it. any other suggestions??
Old Jun 28, 2012 | 06:43 AM
s2000maniac's Avatar
Does it rev to 9k? If so, it might be just heat from the weather. Try it at night when the temps are a lil cooler.
Old Jun 28, 2012 | 05:19 PM
grays2k123's Avatar
Yes it revs to 9k, it does it day and night
Old Jun 28, 2012 | 05:38 PM
S2KIrishman's Avatar
the car still has to use oil pressure to engage VTEC, regardless of what ecu youre using
Old Jun 28, 2012 | 09:16 PM
grays2k123's Avatar
not with the aem ems: heres two links stating this, they dont go in depth unfortunately, my tuner also stated that it doesnt pay attention to that sensor either
http://honda-tech.com/showthread.php?t=1979991
https://www.s2ki.com/s2000/topic/856...ure-block-off/
Old Jun 29, 2012 | 02:23 PM
franky's Avatar
then wat does aem use for vtec? It's got to be your tuner for sure. He might not know his stuff. If he is good, then you wouldn't have vtec problem.
Old Jun 29, 2012 | 02:32 PM
that doesnt make any sense at all...the whole VTEC system is based on using oil pressure to extend the valves more during crossover...as far as i know theres no other way to achieve this without oil pressure
