Normal?
Old Jul 19, 2018 | 01:24 PM
qokuh's Avatar
Default Normal?
So i am going to travel 3 hours to buy a 2003 w/ 14k miles. I know no one has x-ray vision but does anyone see any red flags? It's a two owner car with carfax to prove. Some of the stuff to me looks oxidized--he states it has been in a heated garage and the body looks as if it has. Also, If you zoom, there is red on bolts that i am wondering if should not be. I am consulting you all to tell me if these are normal findings.
Seems oxidized to me
Is that red normal?
Is that red normal?
Old Jul 19, 2018 | 01:31 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Based on the corrosion on the VTEC solonoid valve, inspect the underside of the car for any heavy corrosion.
Old Jul 19, 2018 | 02:22 PM
qokuh's Avatar
Being new to this, i guess other than the obvious, does anyone have photos of a car with heavy corrosion? any comment on those red bolts or screws?
Thanks
Old Jul 19, 2018 | 02:30 PM
Manga_Spawn's Avatar
Site Moderator
I mean the brake fuild looks like it may be getting close to a change but that is a pretty damn clean AP1 engine bay. Still not a bad idea to check the underside of the car for heavy rust (rear wheel wells are another good place to look as there should be little to no rust there). I would sort of expect the valve cover or other parts to show worse wear if there was signs of really bad corrosion on the car though. I am not sure about the red bolts. I think sometimes there is paint or making on them from the factory but can't speak to the ones pictured.
Billman250's Avatar
Top Answer: 1
Yes the red paint on the bolt heads is from the factory.
Old Jul 19, 2018 | 03:06 PM
NNY S2k's Avatar
Might be, but different batteries.
Levi
Old Jul 19, 2018 | 03:35 PM
qokuh's Avatar
Levi
THANKS!!
Old Jul 19, 2018 | 04:43 PM
qokuh's Avatar
THANK YOU, thats really what i wanted to know.
Old Jul 23, 2018 | 09:52 AM
jyeung528's Avatar
keep us updated, good luck.
Old Jul 23, 2018 | 10:17 AM
qokuh's Avatar
we actually ended up getting the car. 12.5k miles for 23.500. Overall it’s good but I think it sat for 2 year before it was bought.
