Noticing some alignment problems
So on the freeway is when I'm starting to notice that when ever i let off the gas, the car starts going to the left but when I gas it, it kind of turns to the right. I feel it slightly when gently holding on the wheel. Is there something loose in the chassis that needs more support? It's hard to describe but I'm wondering if it's bad alignment (doubt it) tire sucks, lsd, need extra bracing on the engine, or sensitive powersteering. The road aren't that great either but I do feel like I'm not sticking to the ground properly like I use to and it's all-seasons tire with plenty of tread left.
Anyone experiencing this? I have a feeling I can drift anytime and lose control EVEN ON STRAIGHTSS
Uneven rear tire pressure is the #1 cause of your problem. Check them again.
If they are even, swith them side to side (temporarily) see if the pull changes direction. This way you can rule out the alignment, or tires.
s2khac
May 22, 2008 04:51 PM
