California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
slight alignment problem after flat tire
Old May 21, 2008 | 09:20 PM
s2khac's Avatar
Default slight alignment problem after flat tire
A screw punctured my rear driver side tire last thursday when i backed out of the garage. I didn't realized it until about 3 minutes later when the car started to swirl, luckily just right before I got on the freeway. So I stopped at the gas station and have the shop there fixed it. They took the screw out, and plugged in the rubber thing that fill up the hole. $15 for 5mins of work, shiet they do make quick money.
Yesterday, I noticed that the steering was a bit loose and a slight alignment problem. So today I checked the tire pressure, and pumped all of them up 40psi, hopefully that would fix it, but nope.
So my questions are could driving for 3 mins with the flat tire lead to this alignment problem? Anything I can check for? How much is alignment normally?
The tires still have plenty of thread. About 5 months old, and probably 10k miles on it.
Old May 21, 2008 | 09:56 PM
Silver5656's Avatar
yup, depends on how flat u were. Do u know if it was a slight flat? or do you think u were rollin on rims flat? Also front tire flat would cause a more severe mis-alignment even over a short period of time. In my old civic, i got a flat in a parking lot and didnt notice it for about 10 min on local roads. After I got it patched, i noticed a slight "wobble" in the steering.
Old May 21, 2008 | 10:14 PM
danvuquoc's Avatar
I don't think it's an alignment issue, I think it's a tire damage issue. Rolling on flat can damage the structure of the rubber itself and cause issues that way.
Old May 21, 2008 | 11:05 PM
Voodoo_S2K's Avatar
Old May 22, 2008 | 12:20 AM
itS2Krazy's Avatar
it would take something like hitting the curb to screw up the alignment
Old May 22, 2008 | 09:10 AM
Stephenopoly's Avatar
It shouldn't screw it up... but your tire pressures are a bit high, usually low 30's is the correct pressure.
Old May 22, 2008 | 09:38 AM
s2khac's Avatar
Thanks everyone. It makes sense. I gotta have the tire shop check it out this weekend.
Old May 22, 2008 | 02:48 PM
AsianQing's Avatar
40psi is quite high. I usually run w/ 35psi.
Old May 22, 2008 | 04:10 PM
s2khac's Avatar
^ Yes, I vaguely remembered 35 as the recommending psi when I pump the tires, but wasn't too sure. So I had it at 40 instead. Just to make sure I don't need to pay again to pump. It's free to release it, but it costs to pump in.
Old May 22, 2008 | 04:51 PM
AP2's Avatar
AP2
I would stick to 32psi. 40psi is a bit much and would affect the handling.
p0staboy
Mar 28, 2012 08:53 AM
KawaFord
Apr 30, 2010 08:25 PM
Ap2masta
Sep 9, 2009 01:15 PM
NYMATT74
Dec 20, 2004 12:20 PM
Dorian Gray
Apr 22, 2001 05:47 PM
