NRG ETD Missing Hardware
Old Oct 4, 2011 | 11:04 AM
bnag0's Avatar
Default NRG ETD Missing Hardware
So i just bought an NRG ETD and i believe i am missing a bolt as there are only 2 which must be for the ETD itself. What size bolt is used to mount the small bracket to the engine?
Thanks in advance!
Old Oct 4, 2011 | 02:29 PM
bnag0's Avatar
No one feels like pulling that bolt off quick?
Old Oct 4, 2011 | 10:41 PM
jbee808's Avatar
I took a look at a pic of it and it's very possible that you use existing bolts that are on the car.
Old Oct 5, 2011 | 05:39 AM
bnag0's Avatar
If that is true i am missing the bolt on my engine or i am trying to bolt it up to the wrong spot?
I am almost positive i have the right spot..
Old Oct 5, 2011 | 06:24 AM
jbird0007's Avatar
thats the right spot. i thought it was a bit strange too, i got my nrg damper off ebay, same thing didnt come with that bolt. i ran down to the local hardware store, its an M10 bolt. I bought the shortest one they had (M10x16 i think?) but the threads arent very deep so try to go with something like M10X12 if that exists. also buy a washer/spring-lock washer for between the bolt and the bracket.be careful wrenching the bolt into your block too. even though i tightened mine down as hard as i could, after 5 minutes of driving, the bracket had shifted to one side so that it rested somewhat on the exhaust flange. this is a pretty shitty design imo, the bracket doesnt seem very solid but oh well i havent had any problems with mine yet
Old Oct 5, 2011 | 06:28 AM
bnag0's Avatar
Thanks Jbird,
That just makes me wonder wtf is that tapped hole really for? lol
Old Oct 5, 2011 | 06:35 AM
jbird0007's Avatar
idk i thought that too.
Old Oct 5, 2011 | 07:28 AM
daktruckie99's Avatar
I believe Billman told me once that the threaded hole is for an engine hoist to remove the engine from the car.
Old Oct 5, 2011 | 08:16 AM
bnag0's Avatar
Well that is a fun little fact. Thanks for sharing!
FYI i measured the depth of that hole and its 25mm. so it would probably take a 20mm lg bolt seated flush but when you have the flat washer lock washer and .19" thick bracket a 25mm long bolt wouldn't be a bad idea. I will purchase a few bolts after work and try them out and report back to be 100% on it.
Thanks for all the help everyone, s2ki never lets me down!
Old Oct 5, 2011 | 08:54 AM
jbird0007's Avatar
how did you measure it? it may be that deep, but is it threaded to 25mm? i went for shorter, because after the first few threads it becomes very hard to turn as if its bottoming out
