o2 sensor code bank1
Old Sep 26, 2011 | 10:10 PM
Mannyfresh's Avatar
Default o2 sensor code bank1
Hey guys I just replaced my o2 sensor bank 1 after it threw the code.I installed it and reset the ecu to remove the code and it still came back,new sensor is oem.Any ideas on what to do?
Old Sep 26, 2011 | 11:13 PM
mmm...vtec's Avatar
Its not ur O2 sensor then. There is something wrong before the 02 thats making it read wrong. What was that the only code that was present?
Old Sep 27, 2011 | 03:31 AM
INDYMAC's Avatar
Which sensor on bank 1 did you replace? Maybe you replaced the wrong one?
Old Sep 27, 2011 | 04:21 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
bank 1 sensor 1: in header (pre-cat)
Bank 1 sensor 2: in cat (post-cat)
this engine only has one bank, as do all inline engines.
A V-engine has 2 banks.
Old Sep 27, 2011 | 01:12 PM
Mannyfresh's Avatar
I replaced the one in the header.Code is P0325 knock sensor 1 circuit,the EV circle on the monitor status on the obd2 was flashing as well??,I have an aftermarket header,and testpipe.
Old Sep 27, 2011 | 03:00 PM
s2000maniac's Avatar
looks like you replaced the wrong sensor
Old Sep 27, 2011 | 03:14 PM
Slows2k's Avatar
Some Sentras have epically confusing B1/B2 02 sensors on a inline 4cyl.
Old Sep 27, 2011 | 03:50 PM
Mannyfresh's Avatar
I'm pretty sure I got the right one sensor 1 is in the header,oh and i have the antifowler mod on my testpipe to keep the check engine light from coming on
Old Sep 27, 2011 | 04:53 PM
Billman250's Avatar
Top Answer: 1
If you have a code P0325, you need a knock sensor.
Had the trans or starter out lately?
Old Sep 27, 2011 | 06:03 PM
zb12691's Avatar
knock sensor code so you replaced a o2 sensor?
