o2 Sensor issue...
Old Aug 25, 2011 | 02:43 PM
AP1Driver's Avatar
Default o2 Sensor issue...
So my downstream o2 sensor dies and throws o2 failure code. I replaced the sensor and cleared the CEL. About 100 miles later, CEL again, same code. Cleared it again, haven't driven far/long enough to retest. If it comes back on, what next? Does the ECU in this car need to be hard reset to default by chance?
Old Aug 25, 2011 | 02:54 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Was the o2 broken?
Make sure you dont have a loose cat internal. It will slide into the o2 and break it.
Billman250's Avatar
Top Answer: 1
There is no hard reset. only a memory clear.
Old Aug 25, 2011 | 06:58 PM
mmm...vtec's Avatar
Something is making the ECU throw an O2 code when its not it. Sounds like u might have an exhaust leak post cat but pre O2. How has ur gas mileage been? Also any blinking MIL?
Old Aug 26, 2011 | 09:34 AM
rjones's Avatar
Originally Posted by Billman250
Was the o2 broken?
+1
I bet the cat is broken and taken out the sensor.
Check out this thread
https://www.s2ki.com/s2000/topic/312...rter-failures/
hocuspocus
Apr 22, 2015 05:50 PM
ViperASR
Jan 10, 2013 06:19 PM
Dolemike
Feb 2, 2012 03:05 PM
zeroptzero
Jan 24, 2010 02:46 PM
Ooalloems2koO
Apr 19, 2005 03:38 PM
