Odd noise on crank
Old Mar 18, 2010 | 07:26 PM
robodeath's Avatar
Default Odd noise on crank
When I crank my S2k (2001 with 64k miles) it makes an odd noise that only lasts about 1 to 2 seconds. Almost sounds like the starter keeps going for a second or two after the engine is already running. It's gotten worse over the past few months.
Any ideas? Could it be the timing chain tensioner?
I'll try to get a youtube vid of it tonight, I drove the prelude to work today.
Old Mar 18, 2010 | 07:28 PM
robodeath's Avatar
Ok I just listened to the timing chain tensioner audio clip and that's not it.
Old Mar 18, 2010 | 07:32 PM
robodeath's Avatar
Ok this isn't mine but this is the noise. The first crank is WITH the noise, the 2nd without.
[media]http://www.youtube.com/watch?v=70hDPdXzmDo [/media]&feature=related
Old Mar 18, 2010 | 07:49 PM
rocsix's Avatar
omg. my car does the EXACT same thing.. always the first crank after its been sitting there for a while
Old Mar 18, 2010 | 07:50 PM
id003's Avatar
I think its known as starter stick.
Old Mar 18, 2010 | 07:51 PM
bcs's Avatar
bcs
I have the same thing. But only occasionally. I don't drive my s2000 very often, so I just chalk it up to that. It seems to happen more when I start it the first time after not driving it for a while. But under regular use, it usually goes away.
Interested to see any other comments though. Maybe someone knows what this actually is.
It basically sounds like the starter trying to turn over again after the car has been started. IE: on a normal turn-key car...turning the key to start after the engine is running.
Old Mar 18, 2010 | 08:46 PM
D1sclaimer's Avatar
I have always had that problem on cold starts. But I didn't drive my s2000 at all this last winter so I haven't had it occur lately. I don't know why, but 5W-30 oil (as opposed to 10W-30) seemed to make it go away in the cold weather when I daily drove it all year. Don't know if it was in my head, but it seemed to help.
Old Mar 19, 2010 | 05:32 AM
GoFaassttt's Avatar
This may help or not help you but it cured my starter sticking (overrun) issue.
I came across a post suggesting to quickly hit the starter button hard roughly 10 times before turning on the key.
I gave it a try and I also blipped the start button once or twice with the key fully on.
Old Mar 22, 2010 | 10:55 AM
robodeath's Avatar
So i'm going to assume this noise is ok. Man it sounds awful though.
Old Mar 22, 2010 | 08:16 PM
ndk4's Avatar
same here. mine has almost 80k now, and it just started doing that. It only happened a few times when the car was left outside in cold weather.
