oil at 50%
Old Mar 12, 2010 | 08:25 AM
RekonEyEz's Avatar
Default oil at 50%
sup guys well the ap2 is running great and iv put about 400 miles on her already and def solid. the oil is at 50% (according to the dash) when should i get the changing the oil? and also what brand of oil do you guys prefer ? ( 34000 miles on her ) thanks for the input
Old Mar 12, 2010 | 08:28 AM
sillyboybmxer's Avatar
i use castrol Edge 10w 30
people are gonna tell you to read the oil journals. lots of good info.
Old Mar 12, 2010 | 08:35 AM
MasterForce's Avatar
Looks like you didnt reset the oil life indicator. I personally change the oil like ever 3000 to 3500 miles. I do this case i vtec every minute! I also use mobil 1 10-30.
Old Mar 12, 2010 | 08:36 AM
spets's Avatar
Change it when it gets to 5%. Not going to gain anything by changing it early.
RekonEyEz's Avatar
thanks fellas -ill look up oil journals and see what i can find ty
Old Mar 12, 2010 | 08:40 AM
RekonEyEz's Avatar
k i found the articles but u know on the ap2s it tells you what percentage the oil is at - ( oil life ? ) thats what i was curious about -
Old Mar 12, 2010 | 10:37 AM
rob-2's Avatar
[QUOTE=RekonEyEz,Mar 12 2010, 10:40 AM]k i found the articles but u know on the ap2s it tells you what percentage the oil is at - ( oil life ? )
Old Mar 12, 2010 | 12:31 PM
2slow2Bfurious's Avatar
I'm curious, cause i have an ap1, we have what's called a "maint required light" and all it is is a reminder that comes on automatically at about 7500 miles regardless of the type of oil that you use or the condition of the oil. Just curious to know what does the ap2 manual say regarding this light. I guess what i'm asking is if anyone can quote what the manual says.
Old Mar 12, 2010 | 12:39 PM
Saki GT's Avatar
AP2 also have that light, up until 2006. The minder does a bit more to look at how the car is driven vs simple mileage, but it still seems that people with 06+ models are getting to at least 7,500 mi between changes. That just tells me that an earlier S could go longer than the default 7,500 value.
Old Mar 12, 2010 | 12:43 PM
Saki GT's Avatar
So, you use your tires every minute as well - are you changing them after 30% usage as well?
