oil consumption .. mobile 1?
wow theres alot of people burning oil lol i thought i was one of the few . yea its something with mobile 1 i dont what . but mobile 1 seems to perform the best that y i keep using it . imma try amsoil next time see if that helps . and wow 4 quarts ? thats alot . do u feel anything wrong performance wise ?
and one day i hit vtec and it didnt pull like it used to, so i knew i something was wrong,
the next day i changed the oil and went into vtec and it pulled like it should have
I was burning Mobil 1 in my 01 (about 1-2 quarts) a oil change not driving it too hard. Just a little spirited driving here and there. When I changed my clogged PCV valve I don't burn anything now. Make sure that's not your problem first.
sure its burning it and not blowing it out? synthetics are very thin and when you hit vtec,it will tend to blow it out of the engine vents.i've learned that pending how hard you drive it will affect how much oil it will use. i used m1 at first and was going through 2 qts between changes. switch to castrol high mileage and it only uses 1 between changes. i have 190k on mine and it uses no more than when i first bought the car 5 years ago.
