Oil Cooler Bypass??
coolant flows through those lines. This allows your oil to be water cooled. You could run a water temp. gauge over there but there are better spots like on your intake manifold for that.
It's cools the oil using water. The water temp is suppose to stay set by the radiator and fans at a safe and constant temp. This bypass just flows the water through the cooler in an attempt to cool down the oil as it flow through the filter. It by-passes the water, not the oil.
Does it really work? Who knows. But i think it should be doing at least something.
Oil have higher boiling point than water. So, yes it is effective in cooling down oil temp.
If you have doubt, find the cars with both water and oil temp. gauge and check out the differences in temp.
The manual says to use the right side engine block plug to do a coolant flush, but as my car has a block heater in that location, I use one of those oil cooler lines to drain the water out of the lower block. I can tell you without doubt that those hoses are filled with coolant. One of those hoses takes the water "into" the oil cooling jacket, the other takes the water "out" of the oil cooler and back into the cooling system.
