Oil Leak ?
Old Mar 29, 2007 | 05:21 PM
wazzurp's Avatar
Default Oil Leak ?
Well today I was making sure the oil was full and the filter was tight when my buddy noticed that there was some grime between the head and the block. Does anybody know what would cause this. I checked the fluid levels, the oil, and the coolant, all were normal. Mods are listed in my sig- could krankvents cause some much pressure that they blow the sealant out between the head and the block? It may have just been some grime so I will keep an eye on it. The car has olnly 28,000 miles on it. Anybody with some info please chime in.
Steve
Old Mar 29, 2007 | 05:26 PM
brimstone's Avatar
krankvents prevent the pressure build up, if anything -- you can rule it out.
Old Mar 29, 2007 | 05:32 PM
wazzurp's Avatar
Ohh Ok I will rule out the krank vents. Yeah I have not overreved the engine to my knowledge as of yet..
Old Mar 30, 2007 | 05:26 AM
90crvtec's Avatar
Normal, several threads like this in the past. My car has this too and I don't have krank vents.
Old Mar 30, 2007 | 06:04 AM
vtec9's Avatar
could be oil leaking through pores in the head. this is common. you can rub on some JB weld if you want.
Old Mar 30, 2007 | 06:13 AM
Sideways's Avatar
Grime is normal. Just wipe it off.
Old Mar 30, 2007 | 10:01 AM
jyeung528's Avatar
i can't wipe mine off....i think mine is permanent.
Old Mar 30, 2007 | 12:43 PM
onfire01's Avatar
Banned
Buy some engine cleaner, spray it on a cool engine, use a stiff brush and lightly scrub, let sit for 15 min, cover alt, vtec solenoid and other electronics UTH and then spray off with a light stream of water.. your oil stains should be gone
Old Mar 30, 2007 | 12:46 PM
jyeung528's Avatar
thanks!
what is the vtec solenoid?
Old Apr 1, 2007 | 06:13 AM
onfire01's Avatar
Banned
if you're at the front of the car with the hood up, on the thing on the left side, closest to you on the valve cover, its looks like a cylinder
Matts2k87
Apr 5, 2014 06:49 AM
_brandon
Mar 3, 2014 03:34 PM
99SH
Nov 25, 2011 06:22 AM
ChefJ
Aug 12, 2007 08:36 PM
John MI blk/blk '01
Apr 4, 2001 08:22 PM
