OIL PAN INSTALL
Old May 24, 2013 | 01:12 PM
conzetts2k's Avatar
Originally Posted by oovyman
The Oil pan is on, and has another 7 hrs left for the Ultra flange to fully cure; at this point everything looks good.
Ultra flange comes out of the can a little thicker than I expected. I applied the Ultra Flange as indicated in the manual, laid a straight line around the pan, watched out for gobbing, and did not smooth it out with my finger. I have a little of the gasket coming through on the outside, but wander about the inside. If too much of the gasket seeps inside, can it possibly damage the internals?
I don't believe so, the sealant/silicone is going to harden on the inside and I doubt oil is gonna be strong enough to move that stuff. I used Honda bond on mine and left it sit for like 3-4 days before i put oil in it. LOL I waited mostly cause I was swapping the turbo kit and installed an Inline Pro stage 2 kit and I had the oil pan tapped by inline Pro for their drain line and had an oil baffle installed in case I tracked my car. But I have not had a single issue/leak from my oil pan since Sept 2012 when I did it and she is rolling on 5-6K miles later.
Old May 24, 2013 | 04:58 PM
zeroptzero's Avatar
yeah there isn't much you can hurt if some oozes towards the interior, some material will go in that direction, no worries.
Old May 24, 2013 | 05:51 PM
oovyman's Avatar
Thanks for the reply's!
I have driven the car for maybe 50 miles, and have no issues.
On a side note...
When I took the old pan off, I noticed that there were two gaskets, one inner, and a outer. I find it odd that the car would come from the factory that way, deviating from the repair/service manual.
Old May 24, 2013 | 06:04 PM
zeroptzero's Avatar
On a side note...
That's just the gasket material squeezing in both directions, I am pretty sure they just put the oil pan on without and wait time during the bolt tightening sequence, so the material is pretty thin in the middle and two thicker lines on the inside and outside edge around the perimeter of the pan.
Old May 24, 2013 | 08:34 PM
AZ-S2000's Avatar
Originally Posted by s2klariat
I waited overnight, but probably not necessary to wait that long.
Most say it takes 24hrs for full cure.
Old Jun 5, 2017 | 06:14 PM
jimcity21's Avatar
Default oil pan
Do I have to move anything out the way other then the support bar? Someone mention moving an AC unit or something like that somewhere.
I have to change mine out
Old Jun 28, 2017 | 04:32 PM
icemans2k02's Avatar
Yes support bar needs to be removed and the ac bracket has to be unbolted or compressor unbolted from bracket. It's not too difficult. There are several pan bolts just make sure you have all of them before you start prying.
Old Jun 28, 2017 | 09:46 PM
jaymz's Avatar
Actually inside is where it is most important for the sealant it creates a "dogbone" inside and helps prevent any oil from reaching the seam between the pan and the lower block. I work at a Honda engine plant and this is something we actually check to ensure there is sealant inside the parts whether it be oil pan or chaincase etc.
PersianSTud
26
Feb 18, 2010 10:08 PM
moto2K1
Feb 11, 2006 07:31 AM
jahnke
May 4, 2003 07:36 AM
