oil pressure.........
Old Dec 31, 2003 | 08:29 AM
owenxguo's Avatar
Default oil pressure.........
hey just want to know where do you guys install the oil pressure sensor when you install a oil pressure gauge???
I was try to install the oil pressure sensor (which cames with the gauge) with the stock oil warning light sensor. but the gauge shows the oil pressure only 5.x to 6.x (digital gauge) between rpm 800-2500. I think it should be wrong or it's different read???
help plz......
also where do you guys install the oil and water temp sensor???
Old Dec 31, 2003 | 08:33 AM
wortham's Avatar
go look at the under the hood FAQ thread. there's a link there with install directions from xviper for the temp gauge and oil pressure i think.
Old Jan 1, 2004 | 06:26 PM
owenxguo's Avatar
[QUOTE]Originally posted by wortham
Old Jan 1, 2004 | 06:57 PM
Slows2k's Avatar
I used a Greddy adapter block to install the oil pressure gauge sender. I drilled the stock block drain plug 1/8npt to mount the sender for the h2o temp sender.
Old Jan 1, 2004 | 08:50 PM
Quik S2K's Avatar
--> MOVED TO UNDER THE HOOD <--
Old Jan 1, 2004 | 10:43 PM
owenxguo's Avatar
Originally posted by Slows2k
I used a Greddy adapter block to install the oil pressure gauge sender. I drilled the stock block drain plug 1/8npt to mount the sender for the h2o temp sender. http://gallery.s2ki.com/imagecatalog/image...geview/74961/6/
where can I get a Greddy adapter????and how much???
Old Jan 2, 2004 | 04:45 AM
slalom44's Avatar
Top Answer: 1
You can't use the stock pressure sender. It only sends out a pressure/no pressure signal. You'll have to replace it with the sender that came with your new oil pressure gauge.
Check out Xviper's post: http://forums.s2ki.com/forums/showthread.p...=&postid=999038
Old Jan 2, 2004 | 03:10 PM
Slows2k's Avatar
[QUOTE]Originally posted by owenxguo
Old Jan 2, 2004 | 06:08 PM
owenxguo's Avatar
see what I did
but because my gauges are digital gauge
the gauge shows about 5.x idle rpm and 6.x about 2000rpm. I have mechanic gauge before that shows about 60 and more when push gas.......I dont know how to read this?????? 6.0 what???
btw thx a lot guys
and happy new year
Old Jan 2, 2004 | 06:24 PM
Slows2k's Avatar
Be warned, several people have used a similar set up and had the adapters break, and all the oil pump out of the engine. You need to use an adapter on the oil filter or a stainless braided hose to the sender mounted away from the engine. I have never heard of your brand of gauges, I can only assume that they are gauges that read in metric, where you old gauge read in standard.
