Oil pressure drop when VTEC kicks in
GUys
I have been searching a lot over the web, but I only found one case that has the rocker arm bolts off the vtec valve train loosen...
The setup
AP1 22MIL ORiGINAL MILES
skunk 2 vtec solenoid housing
6266 turbo
oil feed from oem oil pressure gauge
Head was refreshed, springs, retainers from ferrea.
Full blown intake manifold
Aem series 2 tuned making 600whp on pump and direct port methanol
Mugen oil pan
Motul 300 v oil 20w 60
Driven for 5k miles without issues
Oil cooler from mishimoto
No vetec, and oil pressures are normal, 35 psi on idle with warm oil around 90deg celcius and 85 to 90 psis around 4000 rpms
Once vtec kicks in I can only read 65 psi, it was 85 psi from the beginning while on vtec on the dyne
This engines tends to loosen bolts around.. I am afraid I would have a valve train rocker arm cap loosen?
Any advance?? vtec kicks in smoothly and oil level is fine
is there any oil jet, pin or oring to be a problem on the apt
thanks
dj
The setup
6266 turbo
Mugen oil pan
thanks
dj
How long have you used that oil viscosity ? I would suspect the oil pump operation, the oiling requirement in vtec with this engine is huge. There is a pressure relief on the oiling system, perhaps your thick oil is causing the pressure relief to kick in and drop pressure, as the oil pump can't pump that thick oil quick enough. Try a similar run with a thinner oil and see if the numbers change. We don't see too many people using oil that thick so it is hard to estimate how it may affect this engine.
thank you guys!
I will change the fluid and see all the related bolts, but my guess is that the system can not keep up with the long mishimoto oil cooler lines... my best bet would be bypassing the oil cooler but then again check the engine`s oil and water temp..
I did remvoe the oem water oil exchanger, removed and capped the water lines using oem honda hardware.. on a very hot day with the larger FMIC and a/c I can see the water temps would climb to 97 C deg so I turn the a/c off and they goes back to low 90s range..
Something that is curious is when I have the heater ON I would never see the water temp going above 92 on hot days at high boost, the heater water circuit must be helping with head water circulation I might have hurt while removing the stock water and oil heat exchanger water lines, or maybe it is just the s2k engine´s nature when the heater is ON... on our evos subarus and supra the heater On wont do as much effect lowering the water temps as in the S...
I have one spal ultra high performance fan with fan relay and a capacitor in the power line and a kemford UK fan.. so... I have to do one stuff at the time... and forget now about water temps and focus on oil pressure... I really dont want to have a f20c running less than 78 80 psi of oil pressure at 9500 rpms...
thanks for the comments
Btw is there any oil pressure mod to rais a bit the oil pressure that is common on some other engines? you know adding a shim to the spring at the bypass valve?.. or this is not common in the f20c?
did the oil and filter change, retorque head bolts, teared apart all vtec system inspeccted dowel pin, everything was just fine, oil pressure keeps going low after sustained vtec engagement, I am suspecting oil pump pick up to be lossen due to vibrations, no signs of bearing failure in the filter element
the pressure should be at 80 psi at 8500 rpms, it drops to 70, 68 psis only on 4th gears and sometimes on 3th gear.. oil pan is the mugen with the baffle
In order to change the oil pump in the f20c, can it be done with the oil pan removed? or the front timing chain cover needs to be removed as well??
thanks
thanks
