oil pressure gauge
Old Feb 25, 2004 | 09:48 AM
beroznikmal's Avatar
Default oil pressure gauge
Is it possible to use the stock oil pressure sender when installing a mechanical oil pressure gauge?
Old Feb 25, 2004 | 10:55 AM
Sideways's Avatar
A mechanical oil pressure gauge is mechanical, no sending unit. The factory is an electric gauge.
Old Feb 25, 2004 | 11:00 AM
Would I then use a T connector at the stock sending unit and run a tube to the gauge?
Thanks
Beroz
Old Feb 25, 2004 | 11:47 AM
wortham's Avatar
if you plan to run an oil pressure gauge, i'd suggest getting your hands on an oil filter adapter. greddy is what i use. it makes the job of installing it much, much simpler. simply screw off your oil filter, screw the adapter onto the block, screw the oil filter back on. the greddy comes with two 1/8" slots and another one to run an oil line elsewhere. i use it to run my defi oil pressure gauge, and after having no luck finding the parts i needed around town for a T, i went with the greddy.
Old Feb 25, 2004 | 01:06 PM
Never mind...its an electrical gauge and the sender was included.....
Thanks guys.....
Old Feb 25, 2004 | 01:45 PM
xviper's Avatar
Do as wortham has indicated or mount the sender remotely if you are going to "T" into the existing oil pressure outlet. Having two senders on the same port near the top of the engine may be too much weight and the engine's vibration may cause you some grief.
mnr vortx f20c
Nov 27, 2012 08:47 AM
TheProfessor
Mar 22, 2010 08:51 PM
S2k1807
Jan 8, 2008 06:27 PM
BigBodyS2K
Mar 31, 2004 06:07 AM
sfphinkterMC
Mar 7, 2003 03:14 AM
