An oil pump Question
Old Jun 30, 2004 | 12:02 AM
krazik's Avatar
Administrator
no there won't. 99.9999999% of the s2ks are never going to see the G's dave and I make nor would be willing to drop 3-5k for a kit that they dont need.
But I hope dave can make a sub 3k kit as then its cost effective and we'll both have them. But at 5k. Replacing engine yearly or so is better.
Old Jun 30, 2004 | 05:34 AM
honda9krpm's Avatar
krazig, could you post some more info on the accusump?
where and how much for one?
Old Jun 30, 2004 | 06:30 AM
Asura's Avatar
5K is definately to the upper end of what people would pay, but I thought that is what HE was quoted by someone else.
It seems there are more people making the transition to stickier tires.
This would be critical in a competitive situation, like Honda Challenge (don't know what the rules would have to say) or OTC where an engine failure could cost you the podium.
Proactively fitting a modification to a good engine is more desirable and time/cost effective than repeated replacement of blown engines due to the lack of a solution to the original problem.
Old Jun 30, 2004 | 07:48 AM
RWD_RCKT's Avatar
[QUOTE]Originally posted by davepk
The helms indicates a minimum oil pressure of 85psi @ 3K rpm. I wonder what it should be between 5K and 9K rpm? The same 85psi?
Old Jun 30, 2004 | 07:51 AM
krazik's Avatar
Administrator
Funny you mention that.
Dave also had tried 50wt race oil at fontana for the first time.
Is it possible that it contribututed to his failure?
Old Jun 30, 2004 | 08:02 AM
davepk's Avatar
The regulator can be set to any given value in the range of 60 +/- 30 psi. so a regulated max pressure of 90 is attainable.
RWD_RCKT, why not 15-50wt race oil. I regularly use and Comptech recommends 10-40wt redline.
Asura, tell me about it. It sucked having the engine die in the race. Not because i have to fix it. But, because i had a good chance at passing and beating that Vette. Hell i was thinking about how i was going to catch that spec racer.
Old Jun 30, 2004 | 08:03 AM
Asura's Avatar
My oil pressure is 75-80psi on throttle. It varies with RPM slightly. It is effected by viscosity (10W30 vs. 10W40) and volume of oil (if low).
The gauge also tells you if :
*you have loss of vacuum (oil cap or dipstick missing) as RWD_RCKT experienced first hand at Streets of Willow
I wouldn't mind a more sensitive gauge.
ChefJ
Jul 31, 2010 06:11 AM
krazik
Feb 9, 2005 11:56 AM
mikecl713
Jul 19, 2004 10:34 AM
FormerH22a4
Jan 19, 2003 02:41 AM
ok2k
Mar 23, 2001 05:13 AM
