Oil temp sensor placement
Old Jan 30, 2016 | 02:24 PM
flanders's Avatar
Default Oil temp sensor placement
I'm looking to tap my oil pan to fit a temperature sensor and I'm trying to figure out were it could be mounted.
I would like to mount it on the drivers side for the easiest cable routing but I'm not sure if it would be submerged enough.
Here is were I'm thinking it could be placed, this is with around 2 liters of fluid but maybe it's much more during operation?
Old Jan 30, 2016 | 02:27 PM
s2000ellier's Avatar
any reason you are opposed to simply using the drain plug with an adapter for the sensor?
Old Jan 30, 2016 | 02:36 PM
sillyboybmxer's Avatar
That is something??? Ive been avoiding installing my psi/temp gauges because I didnt know wtf to do after that Canton pan crap
Old Jan 30, 2016 | 02:43 PM
Canton pan works great for me... I'm utilizing the extra hole for a sensor on drive side and all.
Old Jan 30, 2016 | 02:48 PM
yamahaSHO's Avatar
Here is where I mounted mine; seems to work fine. During operation, even if not completely submerged at all times, the amount of fresh, hot oil flowing down over it will be constant.
Old Jan 30, 2016 | 02:57 PM
flanders's Avatar
Don't like to mess with a sensor on oil change and I got the pan down now so was thinking of doing it right.
Nice one Jason, was thinking about putting it there as well but wasn't sure it would clear the dipstick.
Old Jan 30, 2016 | 03:22 PM
yamahaSHO's Avatar
My sensor only sticks in the pan a could millimeters. My bung was turned down on the end to fit a smaller hole and welded on both sides. To give an idea where the dipstick lands, you can see the opening for the dipstick in this pic.
Old Jan 30, 2016 | 08:03 PM
afzan's Avatar
I put mine in a similar location
Old Jan 31, 2016 | 08:49 AM
flanders's Avatar
Thanks for the replies, I will try to put it in the same place.
Old Feb 10, 2016 | 09:24 AM
flanders's Avatar
Just a little followup with my result, put in a baffle at the same time.
