Omg Help
Old Jul 8, 2001 | 04:15 PM
SenSpeed's Avatar
Default Omg Help
I was trying to take off my ignition coil cover today but those damn bolts were on toooo tight. I ended up shaving off the teeth on the bolts and I cant figure out a way to take them off now!!!!! ARGH
Old Jul 8, 2001 | 04:32 PM
pellisS2k's Avatar
Which bolts, the cover's allen-type bolts or the coils 10mm hex bolts? And stripping should be an issue if you use the right sized tools
Old Jul 8, 2001 | 04:49 PM
SenSpeed's Avatar
Its the hexagonal bolts that hold down the VTEC sign cover. I used 3/16 which I think was the correct size...OMG
Old Jul 8, 2001 | 04:58 PM
Schatten's Avatar
then it wasn't the right size allen wrench.
here's a tip - try taking them off when the engine has not been turned on for hours. remember, things under the hood heat up, and expand, which makes every bolt a little bit more difficult to unscrew.
Old Jul 8, 2001 | 05:14 PM
DaveZ's Avatar
3/16ths? Isn't everything on Japanese and European cars in metric?
Old Jul 8, 2001 | 05:26 PM
Mindcore's Avatar
I'm going to move this to "Under the Hood" I saw the word wrench
Old Jul 8, 2001 | 05:59 PM
xviper's Avatar
You may need to use a screw extractor, then replace the bolt with a new one. And yes, all nuts and bolts on this car are metric. Using a 3/16 is a no-no!
Old Jul 8, 2001 | 09:01 PM
Prolene's Avatar
Resolution is as per Xviper. Takes 5mm hex.
Old Jul 8, 2001 | 09:06 PM
SenSpeed's Avatar
DOH....Im an idiot
Old Jul 8, 2001 | 09:11 PM
xviper's Avatar
DOH....Im an idiot
Don't feel so bad, everybody does something like at least once in a lifetime. Thank yourself for not snapping the top off a sparkplug when it's still in the hole. I hear this happens from time to time.
