Optimum Ride Height
Originally Posted by HunterEz' date='Mar 28 2007, 01:12 PM
I measure from the fender lip to the ground, gap measuring is too vague. I am 25 1/8" on front and rear. My car is corner balanced. YMMV
what do you do about the driveshaft spacing?
do you have J's spacer?
what are your thoughts on that issue?
Originally Posted by iDomN8U,Mar 28 2007, 05:18 PM
Dont think pss9 is meant to ride that low.. IIRC it's max is 45mm
max frnt adj : 310mm - 345mm from tp spring pearch to cntr mount screw
------- 12.2047" to 13.5827" and I'm 12.5 in the frnt --- safe
max rear adj : 205mm-215mm from tp spring pearch to cntr mount screw
-------- 8.2677" to 8.4646" and i'm 8.25 in the back -- to low --
I'm going to get it closer to 8-7/16" (8.4375")
Another alternative might be to bump up the spring rates, I'm not sure what tolerances the shocks can handle up to, but maybe around 20% increase shouldn't be overwhelming.
I'm seriously thinking about these shocks
