Overheating
Old Aug 19, 2016 | 06:55 PM
Chilis2k's Avatar
Default Overheating
I just rebuild the motor new Pistons gaskets everything and it shows that its overheating I did change the temperature sensor thermostat and still and it shows 220 just sitting there and if I move for a cruise it can go up to 240 idk what I could be please help thank u all
Old Aug 19, 2016 | 09:15 PM
windhund116's Avatar
The car maybe low on coolant. Air trapped in engine has escape and lowered the coolant level.
Old Aug 20, 2016 | 07:15 AM
Chilis2k's Avatar
I did flushed and still doing that I heard that u got calibrate the AEM ecu some like that
Old Aug 20, 2016 | 04:56 PM
Old racer's Avatar
When I bought my S, with 17000 miles at the time, I had a full dealer service including a change of all fluids. I had driven it about 700 kilometres by then.
The dealer is 38 kilometres away, with some expressway, a little suburban & mostly good country road driving.
On the way home it was getting well over normal temperature, but not really hot. about 3/4 on the gauge, just enough to be a bit of a worry. At home I found it down on coolant, & was surprised to find it took only about 2/3 pint of coolant to fill it. The dealer had obviously not quite filled the system, probably due to a small air lock. This had cleared in the drive home.
With that it full it runs on perfect temperature & never varies. From this I'd say it doesn't need to be very much short of coolant for an S to overheat. I'd look for an air lock in yours.
Old Aug 21, 2016 | 05:59 AM
Chilis2k's Avatar
Thank u I will try again
Old Aug 21, 2016 | 06:06 AM
This may help. Good luck!
https://www.s2ki.com/s2000/topic/106...coolant-bleed/
Old Aug 21, 2016 | 11:32 AM
Chilis2k's Avatar
Thanks a lot man I will try that
Old Nov 7, 2016 | 12:37 AM
Chilis2k's Avatar
I did work an I wrapped all the hot pipes thank u
Old Nov 7, 2016 | 02:54 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the heater does not blow hot hot air, then there is air in the system.
Chilis2k
Nov 7, 2016 12:38 AM
manonastick
Jul 23, 2015 02:57 PM
DrewKC
May 25, 2010 03:35 AM
9kscream
Nov 19, 2003 04:28 PM
warpspeed
Apr 9, 2001 11:25 AM
