OXYGEN SENSOR ISSUE
Old Mar 5, 2012 | 02:01 AM
IMSMEISTER's Avatar
Default OXYGEN SENSOR ISSUE
Hey Guys
Popped into the Honda dealership this morning and picked up a fault with my front Oxygen / Lamda sensor.
After further investigation, found that the wires were sheared.
Got a quote for R 2095 (USD 268)
This is quite steep. Are these sensors car specific or could I go to a parts shop / scrap yard and get an alternative?
Thanks
Old Mar 5, 2012 | 02:39 AM
OneSilverS2k's Avatar
Originally Posted by hecash
How the hell did the primary O² sensor wires get cut? You can't even drive an S2000 off road with any risk to it.
Yah, I am pretty curious too? Weird stuff I suppose happens.. As for the sensor, I mean, my RSX-S I put a $70.00 USD sensor on it ( Bosch ) and it was perfect. A new sensor every 70K on a car is a good things to do. New o2 sensor's give you better gas mileage like it came from the factory. Just because these work, does not mean they're working at their peak.
Old Mar 5, 2012 | 02:40 AM
IMSMEISTER's Avatar
I would expect to be able to purchase a universal (NKT, Bosche) 4-wire, heated O² sensor for about $US70. If the connector is compatible, I would generously expect 5 minutes to get the car up on a lift, 5 minutes to swap in the new sensor and 5 minutesto get the car off of the lift. If the connector is not compatible, add another 15 minutes to splice the original connector onto the universal.
Thanks bud - will give it a shot
Old Mar 5, 2012 | 02:41 AM
IMSMEISTER's Avatar
LOL - beats me.
Old Mar 8, 2012 | 01:49 AM
IMSMEISTER's Avatar
Bought a universal Bosch sensor and popped it in. the CEL is gone.
Before the CEL came on, my car would jerk at times between 1000 and 3000 RPM from pull off - regardless of throttle position.
when the CEL came on, the car drove absolutely smoothly with no jerk. Drove the car for a couple of days before I fitted the new sensor with no issues.
Fitted the new sensor and immediately the jerk was back
Could this be a tuning issue (air/fuel) mixtures?
I have a UNIQ piggyback management.
Old Mar 9, 2012 | 12:16 AM
IMSMEISTER's Avatar
BUMP
AROD
May 28, 2007 12:16 PM
