P0135.. Damaged cat as well?
Old Mar 18, 2016 | 09:14 PM
calvinnnnn's Avatar
Default P0135.. Damaged cat as well?
Got the code to (possibly) replace the pre-cat o2 sensor but I'm wondering if this code could also mean that the catalytic converter needs to be replaced as well? If that's the case, what's the deal with Honda's warranty regarding the converter? Is it less than 80k miles or less than 80k miles AND 8 years? Thanks in advance.
Old Mar 19, 2016 | 12:58 PM
windhund116's Avatar
Why do you think the cat is bad? Have you replaced the front O2 sensor, before? And the CEL came back? P0135 seems to be only O2 sensor related.
http://www.autocodes.com/p0135_honda.html
Old Mar 19, 2016 | 01:43 PM
cbezzy01's Avatar
Its 80k miles or 8 years from original purchase date. Whatever comes first
Old Mar 21, 2016 | 07:55 PM
calvinnnnn's Avatar
Well dang. Hopefully the cat is okay. Thanks.
http://www.autocodes...0135_honda.html
I don't actually think the cat is bad.. I did a lot of searching on here (maybe a little too much lol) before I posted and there were a few posts that mentioned that a damaged catalytic converter was a relatively common issue and it usually coincided with the o2 sensor going.
I have not yet replaced the o2 sensor and it does seem like it's just related to the o2 sensor as I can smell gasoline whenever the top or windows are down and I'm at idle.
Just to verify, the o2 sensor I need to replace is the upstream/pre-cat one correct?
Old Mar 21, 2016 | 10:28 PM
flanders's Avatar
If you keep driving with a faulty sensor the cat will get damaged.
Yes it's the upstream one.
Old Mar 21, 2016 | 10:46 PM
cbezzy01's Avatar
Yes the upstream one. About a year ago I was driving around with that faulty sensor and it ended up busting up my cat but luckily my S was still covered by the federal emissions warranty so honda replaced my cat with a brand new one
Old Mar 26, 2016 | 07:22 PM
calvinnnnn's Avatar
So I replaced the sensor and about 20-30 miles later, the CEL came back on again. What else could be wrong?
Old Mar 26, 2016 | 09:24 PM
P0135, again? How did you reset the original CEL error?
Old Mar 26, 2016 | 11:31 PM
calvinnnnn's Avatar
I reset it by using an OBD scanner. Why? Is that unusual?
Old Mar 26, 2016 | 11:33 PM
No, just wondered if you reset it by disconnecting the battery. Same CEL P0135 error?
