P1106 Code Help
Old Jul 17, 2005 | 05:56 PM
folex187's Avatar
Default P1106 Code Help
I have updated the title of this thread to reflect my problem. Here's the story
I get a CEL light for 2 logs: P1106 and P1106. I have checked my ESM wires over and over and they have SOLID connections. Comptech thinks I might have messed up my ecu during the numerous reconnections I did to the ESM box.
Do you think I need a new ecu?
Slow S2k- you posted about a scan tool. Where would I come up with one? Would this be something Honda had and could pinpoint my problem?
Finally, does this code error throw the car into "limp mode" I have noticed that it runs like complete crap after the light comes on.
Old Jul 17, 2005 | 06:25 PM
revhi's Avatar
P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
Old Jul 17, 2005 | 07:41 PM
Slows2k's Avatar
P1106 is usually seen with a car using some type of piggyback fuel computor, because the piggyback is screwing with the MAP sensor signal. (VAFC, E-Manage) It's also seen with a Comptech ESM or any MAP clamp, with a faulty connection.
On stock cars it is rarely seen. The troubleshooting form the SM pretty much says if it recodes swap a known good PCM, as the BARO sensor is built inside the PCM.
Old Jul 17, 2005 | 10:00 PM
folex187's Avatar
Hmm.. The OBDII reader says Air/Fuel Meter Measurement Parameters or something along that line. The connections on my ESM are perfect. I fished the wiring harness to through the firewall and made all connections outside the car and had others inspect them. The odd thing is my esm box reads 2.93-2.94v which is beyond where it is supposed to cut off right?
Old Jul 18, 2005 | 04:12 AM
Slows2k's Avatar
I'd turn the the clamp volts down some, 2.85 is what Vortech uses on there MAP clamp.
Old Jul 18, 2005 | 02:34 PM
AusS2000's Avatar
That is correct for the Comptech ESM.
Old Jul 18, 2005 | 02:37 PM
folex187's Avatar
Any idea why I'd be throwing the code?
Old Jul 18, 2005 | 02:50 PM
Slows2k's Avatar
Double check the connections on the ESM. are you using t-tap splices, solder or butt connectors. Etc?
2.93V is the spec from Comptech.
http://www.comptechusa.com/instructi...050install.pdf
It's possible your BARO sensor readings may be lower than most due to the altitiude, and the MAP volts is going higher than the BARO. You'd need a OBDII scan tool to verify this.
MAP is used to verify correct BARO operation.
Old Jul 18, 2005 | 03:04 PM
folex187's Avatar
Connections are strong. Soldered and shrink wrapped. The only thing that could be off is I used wire extensions on the black and red but I used the same gauge wire and soldered them perfectly. The altitude I'm at probably isn't the case.
I have an OBDII scanner and it trips the CEL light once I get two P1106 codes. The actual thing it says is "AIR FUEL METERING"
Old Jul 18, 2005 | 03:05 PM
folex187's Avatar
One more question- will this CEL throw the car into limp mode?
