p1456
Old May 27, 2009 | 07:18 PM
K1LL3R 1NS1D3's Avatar
Default p1456
im pretty sure the cause of the cel code p1456 i keep throwing is due to a bad gas cap. anyone know the cheapest place to find a replacement and do i have to get one from honda or is a replacement for like auto zone or napa or something work just fine?
Old May 27, 2009 | 07:31 PM
s2k aok's Avatar
usually every time before i leave it tighten the gas cap. i have a code reader and so i just delete the code. i probably should get a new gas cap but was it the cap or filler neck that had to be replaced?
Old May 27, 2009 | 07:34 PM
i think its just the cap. seems to be the mechanism that clicks is messed up cus it keeps loosening itself up after a day or two if left alone
Old May 27, 2009 | 09:30 PM
omgitsoop's Avatar
gas caps are cheap, call your local dealer and ask
Old May 28, 2009 | 07:41 AM
local dealership has them for $20 so thats not bad. i was just wondering if there was another alternative cus that place is usually outrageously priced
Old May 28, 2009 | 03:30 PM
siik_ap2's Avatar
can be a cap, could also be many other parts...go to your dealer and have them run an evap test if the cap fails to fix the issue
Old May 28, 2009 | 04:30 PM
Slows2k's Avatar
If you are going to replace the cap, only buy an OEM one. The aftermarket caps are horrible about leaking.
Old May 28, 2009 | 05:22 PM
zzziippyyy's Avatar
http://www.hondaautomotiveparts.com/auto/j...cgry5=FUEL+TANK
$13.63
done
Old May 28, 2009 | 05:45 PM
thanks but looks like for once the local stealership will actually be cheaper due to shipping/handling costs.
Old May 28, 2009 | 08:45 PM
MasterForce's Avatar
^yup same goes for me on some other parts...especially the shipping. with the dealership i get 1 or 2 day shipping
