Parking Lights not working
Old Aug 19, 2009 | 05:35 PM
Mister Jew's Avatar
Default Parking Lights not working
hey
quick little question/problem?
02 s2000 the parking lights do not come on either turn the headlight switch or when i unlock/lock the car with the oem alarm.
the lights do work when i use turn signals/hazards.
i am getting no pwr to the parking lights when i turn them on.
any ideas? is there a relay? i have a cd service manual havent seen any info on that.
im thinking its the headlight/wiper switch?
any info lmk thanks
Old Aug 19, 2009 | 05:49 PM
wisdom's Avatar
Hmmm... parking lights come on with the first click. Well theres two sets of lights at the corner of the assembly. The top part is the signal light and the bottom are the parking lights, its a really small bulb.
Maybe burnt bulbs or fuse?
Old Aug 19, 2009 | 05:54 PM
Mister Jew's Avatar
check fuses and bulb is fine.
im not getting pwr when i turn to the first click "parking Lights" on the headlight switch
Old Aug 19, 2009 | 05:56 PM
Mister Jew's Avatar
btw the rear lights work fine.
its the front turn signal parking lights im talking about
im gonna test the headlight switch and try and find a wiring diagram i can read
Old Aug 20, 2009 | 04:49 AM
AngryTurtle's Avatar
The switch works fine if the rears ore turning on. how do you know the bulbs are good?
Old Aug 25, 2009 | 07:31 PM
Mister Jew's Avatar
checked the switch out its fine.
bulbs are good because i have ohms when i measure them.
they flash with the turn signals also.
any ideas?
i hate driving without my parking lights on
Old Aug 26, 2009 | 12:11 AM
Siggy's Avatar
perhaps just check the clip/wire connection, should have been jiggled loose ect.
if its not the bulb, it must be the wiring/connection or the fuse
Old Aug 26, 2009 | 05:24 AM
Mister Jew's Avatar
the connector is intact and the wires are secure.
i been reading through the service manual ill have to read the wiring diagram more.
Old Aug 3, 2011 | 10:09 PM
Rasetsu99's Avatar
Sorry to bring this post back from the dead, but did you ever figure out what was causing the issue? My 03 just started to do the same thing. The drivers side parking light does not come on, but when I turn on the signal it works just fine. I just replaced the bulb and it still is not working.
Old Aug 6, 2011 | 12:31 PM
S2k_fever's Avatar
Aren't the parking bulbs different than the turn signal ones? They have nothing to do with each other.
