passenger window
Old Sep 26, 2010 | 08:18 AM
kmengys2k's Avatar
Default passenger window
i can hear it click but cant hear the motor turn...i check the driver elbow lock switch and did not hit it by accident...check the fuses, its all good,soft top goes down as will and driver side window, but passenger does not roll down... any help????????
Old Sep 26, 2010 | 09:59 AM
RacerXI's Avatar
Broken regulator? Can you remove the door panel and take a look?
Old Sep 26, 2010 | 02:16 PM
D_Spec's Avatar
Mine did this. The cable on the regulator broke on mine. Unfortunately its all once piece and cant just fix parts on it, but they can be found pretty cheap used. I paid 50.00 for a used one. I think they are around 300 from Honda.
pretty easy to install also
Old Sep 26, 2010 | 06:03 PM
kmengys2k's Avatar
the cable seems fine when i looked at it... what does the regulator do and what does it look like??? could it be just the regulator or the motor???
Old Sep 26, 2010 | 06:12 PM
D_Spec's Avatar
well the regulator, motor and cables are all once piece. Then next thing to try would be the module under the passenger side of the dash. My friend had this go out a year or so ago. I can not remember the name of that piece. We tested mine on his car to see if that was indeed the problem. I will try to find out what that relay/module thing is.
Old Sep 26, 2010 | 06:15 PM
D_Spec's Avatar
Convertible top module is the part we replaced on his. But I just read your top works. sooo Im guessing its the regulator.
Old Sep 26, 2010 | 06:23 PM
D_Spec's Avatar
here is a DIY if needed.
https://www.s2ki.com/home/2010/08/19/diy-ho...regulatormotor/
Old Sep 26, 2010 | 11:33 PM
badboy00z's Avatar
My driver side window won't work at all and I don't hear the click when I press the button. Is this a regulator problem as well??
Old Sep 27, 2010 | 02:15 AM
D_Spec's Avatar
More than likely. Check for blown fuses first. Does your top go up and down?
Old Sep 27, 2010 | 08:49 AM
badboy00z's Avatar
Yes my top works and the passenger side window goes down with it but the driver side window doesn't. Which fuse is for the windows?
