Passenger Window doesn't roll up or down
I couldnt find the threads when i search i remember seeing it too then got lazy to fix it until now
my problem is that my passenger window doesn't roll up or down
To roll down I pull up ebrake and press down the convertible button down to roll down (which work 50% of the times)
To roll up I have to play with the passenger switch lock switch, IF i switch from lock to unlock, the window automatic roll up
the roll down or up button doesn't work both driver side and passenger side
So can anyone help?
So can anyone help?
Then try a site restricted Google search:
https://www.google.com/search?q=Passenger+Window+doesn't+roll+up+or+down& rlz=1C1CHKZ_enUS437US437&oq=Passenger+Window+doesn 't+roll+up+or+down&aqs=chrome.0.57&sourceid=chrome &ie=UTF-8#safe=active&rlz=1C1CHKZ_enUS437US437&sclient=psy-ab&q=Passenger+Window+doesn%27t+roll+up+or+down+si te:s2ki.com&oq=Passenger+Window+doesn%27t+roll+up+ or+down+site:s2ki.com&gs_l=serp.3...1498.3865.1.40 66.14.14.0.0.0.0.130.1135.12j2.14.0...0.0.0..1c.1. 15.serp.d6GIjezaseY&psj=1&bav=on.2,or.r_cp.r_qf.&b vm=bv.47244034,d.dmQ&fp=5393aa61aebcf3f&biw=1920&b ih=995
Take off the door panel and unplug the connector on the window motor. Run wire from the negative and positive post on the battery and touch the two pins on the window motor. If the window goes up, then there is a wiring/switch issue. If the window does nothing, try switching the wires. Still nothing? Window motor needs to be replaced.
