passenger window problem
Old Feb 22, 2011 | 05:12 PM
keemaca's Avatar
Thumbs up passenger window problem
First just want to mention it's not the lock window button that was the first thing I checked, wasn't the fuse eather checked those already, also not the driver switch since the passenger was giving the same results. I searched but couldn't find a specific answear to point at the problem, mostly just people who had the lock on, I'm guessing it's most likely the motor but just want to make sure before buying another one. Well today I noticed the window didn't come up right away pushed the switch again, then it worked so didn't put too much thought into it.. drove off again the window didn't come down messed with the button a little, window came down then had a little bit of a hard time to get it back up so left it there so it doesn't get stuck while open ..doe's anyone have a idea if this would be the motor going out..? or can it be something else..? thanks ahead for any help you guys can give me ..
Old Feb 22, 2011 | 08:49 PM
keemaca's Avatar
anyone..?
Old Feb 22, 2011 | 10:41 PM
murd0x's Avatar
it might be your window switches.....happened to mine not to long ago my driver side window switches went bad and kept the switch polarized down so the window wont come up which burned my passenger window motor had to get them both replaced.
Old Feb 23, 2011 | 10:26 AM
keemaca's Avatar
well I took off the door pannel today couldn't source the problem..I have no idea what's going on, something is deffinitely going wrong, when I would use the driver switch the window would come all the way down automatically and sometimes won't go up,the driver window is working perfectly so I doubt it's the switch, but the passenger switch was working up and down, also the window will vibrate while the last half goe's down...has anyone had this happen or something similar..?
Old Feb 24, 2011 | 09:23 AM
keemaca's Avatar
bump for a little help..
Old Feb 24, 2011 | 10:41 AM
lltysonll's Avatar
I remember reading a while back that a bar after years of use, eventually snaps. There is a fix with pictures somewhere in here. If I can find it I'll link it bi might be what your experiencing.
Old Feb 24, 2011 | 10:42 AM
lltysonll's Avatar
If I recall the thread post was also a fix for the passenger window.
Old Feb 24, 2011 | 10:57 AM
keemaca's Avatar
^thanks I been reading through alot of threads but can't find anything that helps ..please let me know if you find anything..thanks again
Old Feb 24, 2011 | 11:25 AM
lltysonll's Avatar
did you hear a popping sound?
https://www.s2ki.com/home/2010/08/19/diy-ho...regulatormotor/
Hope this helps.
There is another thread about a noise under the dash when pressing the switches. Are you experiencing that noise?
If so let me know I can find the thread for you.
Old Feb 24, 2011 | 11:28 AM
lltysonll's Avatar
its also possible your window regulator is dying.
