PC680 battery -- cannot be right?
Old Feb 19, 2015 | 11:32 AM
cdelena's Avatar
Originally Posted by SheDrivesIt
There was a pretty solid history of failure for type 51 Optima Yellow Tops some years ago. Have they solved their quality issues for that model? Hope so.
A local member got stuck with a replacement unit several years ago (retailer would not refund cash) so I bought it and it has been excellent thus far.
Old Feb 19, 2015 | 11:55 AM
Redline S2K's Avatar
My yellow stop died suddenly with no warning. Drive to work no problems, went to lunch (at home), also no problems. Went to go back to work.....no start. Grabbed my DVOM and checked voltage....6 volts.
Old Feb 19, 2015 | 01:42 PM
zeroptzero's Avatar
I replaced my Optima yellow top with a 17 lb Braille. My yellow top was working fine and I don't have anything bad to say about it, but I liked the 12-13 lb savings, and the Braille has more cranking power. It has worked flawlessly in 2 years of service. In two years of use it still tests out at 495 CCA, it has an advertised CCA of 475, pretty good IMO.
The only thing you have to be careful with is using power when the vehicle is turned off - cranking the audio with the vehicle shut down - once they run dead they are difficult to bring back to life.
My Braille weighs less than my cat lol . The only thing better IMO would be a lithium battery but I'm quite happy with the Braille (lead AGM battery). They have even smaller batteries but the 17 lb is a nice balance between CCA and capacity.
Old Feb 19, 2015 | 06:17 PM
nissanfanatic's Avatar
My PC680 has sat for quite a bit. I just disconnect the negative battery terminal when it is gonna sit for a while. Fires right up every time.
Old Feb 20, 2015 | 04:23 AM
This is the battery I'm running right now. Stronger and lighter than a pc680 or Braille battery. Just over 3 pounds.
Old Feb 20, 2015 | 08:58 AM
tiger1964's Avatar
Posts 11, 12, 13 & 14 show the varied on-line reputation -- such as on many other products.
Once it arrives, other than resetting the radio security code, any other caveats beyond hooking it up and driving off?
Old Feb 21, 2015 | 05:49 AM
rtboy10's Avatar
Originally Posted by JFUSION
I replaced my Optima yellow top with a 17 lb Braille. My yellow top was working fine and I don't have anything bad to say about it, but I liked the 12 lb savings and the Braille has more cranking power. It has worked flawlessly in 2 years of service. The only thing you have to be careful with is using power when the vehicle is turned off - cranking the audio with the vehicle shut down - once they run dead they are difficult to bring back to life.
Does the Braille battery for in the oem tray? Any modifications needed? Thanks
Old Feb 21, 2015 | 06:00 AM
zeroptzero's Avatar
It fits in the oem tray since it is smaller. Braille supplies you with a new hold down clamp. I am presently using the oem hold down clamp (metal) though and it seems fine.
Old Feb 22, 2015 | 01:38 PM
clio's Avatar
My PC680 has been fine, about 1 and a half yrs use thus far. I use the car as my daily.
Old Jan 5, 2016 | 03:50 AM
tiger1964's Avatar
I chose the Optima, and have to admit, the OEM battery was working fine so the new one sat in the garage for TEN MONTHS or so before I saw a weather forecast for truly cold weather, and installed it over the weekend. Got lucky, the old battery never failed.
