Piston movement
Old Mar 18, 2012 | 12:17 AM
bobonacus's Avatar
Default Piston movement
Should the pistons move at tdc? Mine wobble a tiny amount but I would have thought there should be no movement at all?!
Old Mar 18, 2012 | 12:27 AM
SpitfireS's Avatar
Move up & down or sideways?
BIG difference.
In theory, every degree, minute or second of crank rotation from TDC will move the piston down.
In reality there is a tiny amount of play in all the journals between piston & crank, but.. that play is filled with oil.
Old Mar 18, 2012 | 04:17 AM
bobonacus's Avatar
They move back and forward in the bore
Old Mar 18, 2012 | 04:53 AM
nissanfanatic's Avatar
There is a spec for it.
Piston-to Cylinder clearance:
Standard(New): 0.004-0.027mm (0.0002-0.0011in)
Service limit 0.04mm(0.002in)
Old Mar 18, 2012 | 08:32 AM
zeroptzero's Avatar
they will definitely move, the question is how much movement, the specs listed above are to be used to determine that. Your method doesn't reveal much unless you are experienced with a number of new and used S2K engine blocks. Someone with Billman250's experience would likely be able to tell by eyeball or feel but I couldn't.
Old Mar 18, 2012 | 08:45 AM
bobonacus's Avatar
Thanks for your replies, I'll get my feeler gauges out
Old Mar 24, 2012 | 11:04 AM
bobonacus's Avatar
I measured at the top of the piston (looking at the service manual it shows measuring at the bottom) and they are all about 0.5mm! Seems odd they are ALL way, way over 0.04 by about the same.
Measured at tdc and about halfway down the bore, less further down but still about 0.4mm
Is the service manual correct?
Old Mar 24, 2012 | 11:15 AM
bobonacus's Avatar
Extract from service manual
Old Mar 24, 2012 | 06:16 PM
Nutterbutter's Avatar
The correct way to check piston to wall clearance is to use a bore gauge to measure the bore and a Micrometer to measure the piston 1/2" from the bottom of the skirt. It's going to be hard to get a solid measurement with feeler gauges.
What kind of mileage on the Motor? Pistons will "rock" at TDC since most are tapered at the top. Stock PTW clearance is so small that there should be very little "rock" at TDC.
Old Mar 24, 2012 | 10:47 PM
bobonacus's Avatar
It has done 100,000 miles
Maybe I should start a new thread with the symptoms as I'm trying to understand what the issue is, I thought head gasket but that seems ok, no obvious failure so I was thinking maybe pistons or rings
