Piston Set Question
Old Feb 19, 2006 | 08:53 AM
CrazyCracker82's Avatar
Default Piston Set Question
if you go HERE you will see at the top a piston Set A (std) and a Set B (std) and of course the .25 OS Set.
my question is, what is the difference between A and B? I'm looking to do a small rebuild and just give my engine a refresh. Nothing to crazy....yet
Thanks for the help in advance guys
Dan
Old Feb 19, 2006 | 10:12 AM
cdelena's Avatar
Apparently two different pistons were spec'd to be used depending upon how the block measured at assembly. The 'B' pistons are 4/10,000 larger in bore size. I think you would have to look at what you have to know the proper replacement.. they have either no stamp on the skirt for 'A' or a 'B' stamp.
Old Feb 19, 2006 | 03:55 PM
cool thanks for the info.
and a just making sure......when it says piston set is that all 4 or a single piston?
2 fast for u
Oct 16, 2009 11:00 AM
redskel
Car Talk - Non S2000
Feb 26, 2009 02:09 PM
buckstarr
May 15, 2004 08:24 PM
