Please ease my worrys
Hey guys, and thanks in advance for any help you can extend me here. I recently purchased a NFR MY00 s2k with ~70k miles on it. Having never owned an s2000 before, there are a few things I am worried about, mostly in the area of sounds/feelings the car makes, as listed below.
1. A small rattling sound that seems to come from the transmission, gets more intense as rpm climbs, also makes this sound when clutch is pressed to floor and when car is in nuetral. Could this be my aftermarket exhaust rattling, or something more serious?
2. Second gear. It seems alot harder than the rest to shift into, from what I've read this is a problem in earlier MY of s2000, but I'm not sure if my problem is the same, as it's only shifting INTO 2nd, and mostly only from first, that causes it to feel stiff.
Like I said, any help here would really be awsome, as these issues (mostly #1, wich I just noticed tonight) are eating away at me inside
For Question #1 check for any loose nuts inside the engine bay. Better if you from the bottom of the car. I had a loose nut around the engine bay that was causing a rattling sound also.
Also does the car vibrate a lot?
As for it being a throwout bearing, would it contribute that my clutch seems to vibrate a bit during engadgment? I can hear a slight grinding sound when it engages, but can't feel the clutch slipping at all?
laterz
Aug 27, 2013 02:44 AM
