Please help !
Old Nov 18, 2012 | 03:56 PM
kidxsai's Avatar
Default Please help !
So I have been experiencing some problems with the clutch lately. It feels like it gets stuck. If I wanted to start the car I would have to push onto the pedal almost full force to press it down to the floor. It would get stuck hard everytime I changed gears or rev-ed up.
Another thing was I felt like the car lost power to accelerate from a stop. Although it was in the first gear but the car didn't seem to accelerate like no pressure at all.
Please give me some advise. I don't know what to do
Old Nov 18, 2012 | 04:16 PM
jc2078's Avatar
Check your clutch fluid (located in engine bay on driver's side I think). If it is low or empty you have a leak somewhere in the system. Possibly at the master/slave cylinder. To check the master cylinder follow the clutch pedal up to where it connects to the car and see if there is fluid or it is wet.
When you mean stuck do you mean stuck at the top or bottom of the pedal movement?
Old Nov 18, 2012 | 04:29 PM
kidxsai's Avatar
It's stuck at the top when you begin to push the pedal. I'd checked the fluid in the small reservoir and it was full. But the fluid was dark. I believe there are 2 reservoirs but I don't know which one is for the clutch.
And what about the power lost? Does it have anything to do with the clutch at all?
Old Nov 18, 2012 | 04:40 PM
jc2078's Avatar
The larger one is for the brakes and the smaller one is for the clutch. Dark is fine, it usually gets dirty very quickly. If the clutch does not engage/disengage fully it could result in power loss. I am not sure of what is the cause of your clutch problem though. Maybe someone else does
Old Nov 18, 2012 | 04:54 PM
kidxsai's Avatar
Thank you.
Should I bring it to a shop? Does anyone know any good shop in NNJ?
Old Nov 18, 2012 | 05:01 PM
kidxsai's Avatar
It freaked me out everytime it lost power. It was like almost no power to accelerate in first gear. Embarrassing
laserred02
Nov 28, 2012 07:12 PM
Fiducial.
Nov 10, 2011 11:26 PM
hi-revs
Dec 29, 2009 04:46 PM
hokiemax
Sep 14, 2008 10:00 PM
RT
Jun 6, 2001 04:26 PM
