PLEASE HELP! Hondata Gasket Q
Hi guys.
I'm planning on doing the Hondata gasket install this weekend, but have a quick question that I couldn't find an answer to anywhere.
What are the washers for in this pic?
I don't have those. Are they needed? If so, are they something I should be able to pick up at a local parts store?
I don't see them in this pic (unless they're behind the actual gasket)
I've read through all the install instructions as well as all the threads pertaining to the gasket install I could find, and no where are they mentioned.
Any help on this is greatly appreciated
You do not need those washers and I have never seen them before!
Also Label your hoses coming off the side of the manifold - I know of at least 2 people that have accidentally switched the coolant/Vaccum hose behind the throttle body and use blue locktite on the mani bolts.
I certainly don't want any coolant getting into cylinder #4!
