Possible engine problem?
Old Dec 11, 2008 | 06:52 AM
da_wesmeista's Avatar
Default Possible engine problem?
The other day on the way home from work I started the car and got a check engine light (cylinder 2 misfire). I was running all 4 cylinders so I replaced the spark plugs and idle/startup is soooo much better. What I'm concerned with I have a '00 w/ 52k miles and it had Bosch plugs in it. Plus the middle two cylinder plugs had no tip left, it looked like they had both corroded. I just bought the car about 3 months ago with 48k miles.
My question is why would it have Bosch plugs in it before 50k miles?
And what could cause them to corrode that bad in the middle two cylinders?
Everythings ok now I just want to take steps to prevent further problems, thanks!
Old Dec 11, 2008 | 07:04 PM
Kirpich's Avatar
Pics!
I heard form a guy who worked on a ton of hondas in the 90's that hondas hate Bosch plugs. Don't know why, though.
Corroded? like rust or deteriorated? Probably severe engine knock/pinging.
Old Dec 11, 2008 | 07:13 PM
newnan-s2k's Avatar
ive heard the same thing bosch and honda DO NOT MIX
Old Dec 12, 2008 | 07:17 AM
Unfortunately I through them away...
There wasn't any rust at all just corrosion.
My question is why the previous owner had to change the spark plugs already
Old Dec 12, 2008 | 08:07 AM
loftust's Avatar
Maybe he didn't bother to read the servicing routine and didn't know that NGKs last for ages.
I'd give her a full service if I were you.
Old Dec 12, 2008 | 06:56 PM
dimi's Avatar
Depends what Bosch plugs they were. In some places it is a hassle to get the OEM NGKs, while other people aren't prepared to pay the steep price. Of course they don't realize what the interval for changing them is.
Old Dec 13, 2008 | 06:24 AM
Yea hopefully that was it
I've pretty much done everything I can think of (trans fluid, oil change, repaired rear bearings and replaced leaking clutch master cylinder). I probably need to change the brake fluid while at it.
Thanks for the input!
Old Dec 13, 2008 | 06:41 AM
00S2K01S4's Avatar
Sparkplugs are pretty cheap. Perhaps he changed them during a maintenance and chose the wrong type of plug? I've changed my plugs on my car about 4 times already and have about 44K miles.
ozk1
Dec 29, 2015 09:55 PM
benzydad
Apr 28, 2010 10:25 PM
jon3501447
Nov 17, 2008 10:33 AM
Morangie
Jul 15, 2002 04:15 AM
