Possibly destroyed the engine, boys.
Old Jan 24, 2008 | 01:00 AM
\\s2kris//'s Avatar
I had the exact same problem with MY00, did you drain the oil yet? Im sure your oil is full metal. You probably spun a bearing.
Old Jan 24, 2008 | 01:01 AM
\\s2kris//'s Avatar
Originally Posted by jyeung528,Jan 23 2008, 10:25 PM
do a compression and leakdown test,
and send in your oil for analysis.
When this happened to me I did a compresion and leak down test wit no problem.
Old Jan 24, 2008 | 03:45 AM
iam7head's Avatar
that's good that the ring are good but the same couldnt say about the bottom end
Old Jan 24, 2008 | 07:54 AM
9KRDLIN's Avatar
change your oil! and if you smell burning oil, check to see where the leak is. it is probably on the exhaust side which explains the burning, otherwise it is internally, and coming out your tailpipes. check around and see where it is coming from.
Old Jan 24, 2008 | 06:40 PM
P5744D's Avatar
welcome to the club
Old Jan 24, 2008 | 09:59 PM
WeezyBaby's Avatar
Well, I won't be able to bring it into honda this week to get them to open up my engine and see if anything damaging has happened. But I did get an oil change, no noticeable metal shavings in the oil, oil did smell slightly burnt. BUT! a huge cause of the smell was a damn plastic bag burned onto my exhaust pipe. Nasty! New oil in, the car is running fine, though i'm probably not going to be revving into vtec until all is known.
No weird sounds from the engine, no dash warning lights, no smoke from exhaust pipes. (plastic bag burning smell is still present even though I scraped it all off). Looks like luck might just be on my side. Honda engines just don't like to break down easily?
Old Jan 25, 2008 | 06:51 AM
LittleBluePill's Avatar
Originally Posted by WeezyBaby,Jan 23 2008, 05:05 PM
So here's how it all starts out. I have an '02 with 54000+- miles. Last oil change was 50000 miles ago.
Is that correct? If so
Old Jan 25, 2008 | 08:16 AM
9KRDLIN's Avatar
i ran my d a quart low a ton of times, and i was boosted 10psi.. they don't die easy... but you were riding a line.
Old Jan 25, 2008 | 08:46 AM
street_ruler's Avatar
compression and leak down will tell you nothing about bearings. the only way to really know is to take off the caps and look.
with the burning smell id almost be tempted to look for an oil leak somehwere.
and the smell when only in VTEC worries me a little
Old Jan 25, 2008 | 08:57 AM
kpap2's Avatar
i think he meant last oil change was at 50000.. or at least i hope..
