Potential problem
Old Aug 18, 2012 | 11:32 AM
s2000maniac's Avatar
Default Potential problem
While looking around today, I noticed this....
Is this going to give me any potential problems? I'm assuming I have to replace the whole control arm since Honda doesn't sell the bushing alone.
Old Aug 18, 2012 | 11:53 AM
MM3Kwolik's Avatar
yes they do....it's part number 20....
http://www.hondaautomotiveparts.com/...=FRONT+KNUCKLE
Old Aug 18, 2012 | 11:54 AM
MM3Kwolik's Avatar
You might as well just replace the whole ball joint though....
Old Aug 18, 2012 | 12:26 PM
okay thanks jordan. the ball joint is number 4 right? thanks
Old Aug 18, 2012 | 01:07 PM
MM3Kwolik's Avatar
No, that's the lower ball joint, you want the upper. I'm not sure if it's something you can get from honda, although I know multiple companies make high quality aftermarket replacements.
Old Aug 18, 2012 | 01:10 PM
MM3Kwolik's Avatar
Just confirmed, if you want OEM upper ball joint, you have to buy the entire A-arm. But like I said, there are other aftermarket companies that make higher quality replacements for the OEM ball joint. I believe Eibach makes them....although theirs might only be offset ball joint replacements...
Old Aug 18, 2012 | 03:04 PM
thanks jordan!
Old Aug 18, 2012 | 07:03 PM
USMC s2k's Avatar
DAMN!!!! looks like your going to need a new engine.... hahahahahahahha
Old Aug 18, 2012 | 07:31 PM
^^^ this guy!! Always Sooo negative...
Old Aug 18, 2012 | 07:40 PM
USMC s2k's Avatar
get out of here!!!!
when are you going to replace that?
