Preload when fitting springs?
Old Jul 26, 2010 | 10:55 AM
r8byb's Avatar
Banned
Default Preload when fitting springs?
I've always thought of preload when fitting coilovers only as the spring preload is adjustable.
However searching on here i see after fitting springs it's best to preload the bushes?
So i presume i fit the springs, lower the car onto the ground, then tighten up certain bolts as they are now "preloaded" as such.
Can anyone simply tell me which of these bolts i need to leave loose then tighten up on the ground?
Cheers
Old Mar 17, 2011 | 12:57 AM
samg1988's Avatar
Did you ever find this out Rob?
Old Mar 17, 2011 | 04:49 AM
AngryTurtle's Avatar
It is recommended to jack up the suspension with the wheel off then tighten all the bolts you loosened to their torque specs.
baldii
Aug 24, 2012 12:40 PM
CynicG
Aug 22, 2012 10:05 PM
PlanesforToday
Apr 4, 2012 04:54 PM
FISH22
Apr 4, 2008 08:45 PM
JS2k.com
Feb 6, 2007 06:26 PM
