prep questions
If you're giving the keys to a pro driver - make sure your tires and brakes are top notch!!!
I think the #1 thing to get are the 265/40-18 A048s for the rear. [There's also a 285, if you can fit it.]
With the power you've got, the rear end is going to be loose with the 235s (compared to the front). The 265s are a closer match to the 225 fronts. The 235s are almost a half inch taller than the 225s, and don't give the proper stagger.
Then do the pads and fluid change.
Good luck!
-Pete
Good luck!
-Pete
davidnyc
Dec 23, 2012 09:40 PM
kleecker
Feb 2, 2006 03:18 AM
SVT_Chia
Mar 21, 2005 09:07 PM
