Press Size - Wheel Bearing / Hub
After receiving rather high quotes to press in a bearing and hub ($80 per side) I am going to purchase a press from HF - what size of press do I need for this? I feel like for $160 I could ship them somewhere reputable rather than Napa down the street?
http://www.harborfreight.com/catalog...result?q=press
20 ton is perfect.
The breakaway force of the bearing from the knuckle is around 14-17 tons. The other forces are likely under 10 ton.
The key to successful pressing is having various collars and round dies to press and support things.
i used a 12 ton with success. I used a torch to heat the hub to help improve breakaway and removal.
I left the bearings in the freezer over night and used a torch to warm the hub prior to insertion. I used a bit of bearing grease to ease it in.
darcy
darcy
A 10 ton press can do the job. 20 is better, even better the one with a strain gauge on top but that's just getting fancy. $80 to press the bearing and hub into the knuckle? That's rape man that's a 10 minute job if that, per side. You're much better off getting a press, at least then you can use the press for other things like bushings, or other transmission or diff rebuild if you ever need it and are feeling saucy.
The chances of me using the press again are relatively slim and apparently a lot of the shops around here charge a minimum of an hour's labor
Given the number of bearings that go out on these I am surprised a vendor hasn't set up a core service...flat rate shipping would keep the cost down
