Primary 02 sensor might be bad(1 in the header)
ECU threw a code: P2A00
Done my research and seems to be a common problem with '06+ s2k's.
Wondering whether I can replace this sensor with an 02 Air/Fuel sensor for any year S2k or whether it has to be an '04+ or '06+ sensor?
Maybe someone on the board has a used one they could sell you. An element broke in the catalytic converter broke and broke off the tip of the 02 sensor but I was able to get a used one from a member and I was back in business for less than the cost of the new parts. 36k mi later and it's still holing up well.
^^ I had that happen as well around 20k miles and both my cat and secondary 02 sensor were replaced under warranty. Now my primary sensor is bad, apparently.
Part #7
http://www.hondaautomotiveparts.com/auto/j...XHAUST+MANIFOLD
http://www.hondapartscheap.com/southbay/js...nt=0&quantity=0
Not as bad as $300+ the dealer charges but still a nice chunk of change for a sensor...
Part #7
Originally Posted by whiteflash,Dec 28 2010, 10:16 AM
Hey out of curiosity was this a result of a recently installed (using that term loosely) Flashpro?
Originally Posted by Rubn1out4GudLuk,Dec 28 2010, 08:23 PM
No, this is more of a result of getting a flashpro and loading the toda tune(a/f ratios dropped in the 10's) and then Mugen header, intake, exhaust tune(a/f ratios dropped in the 9's) and running the toda tune for 2 days or so which probably killed the sensor while running too rich.
