Problem with my car!
Hi when i put the key to start the car the cel light never appear. i think that my ecu is ****!!!
i was getting my cel codes without a scantool and now my car wont start please help me!!!. |
you fried you ecu?
which pins did you connect to each other to try and get the code? |
i have an 05 ecm if you wanna buy one... pm me
/.0000000\
/ 000.0000 \ I connect the two dots |
It's pretty hard to fry the ecu, start pulling the fuses one at time under the dash and under the hood. You probably jumped the wrong jumpers and blew a fuse.
If all your fuses are good, then maybe you did blow the ecu. Scan tools aren't all that expensive guys... certainly cheaper than a new ecu. |
I bought a scanner for $40 at Harbor Freight Tools. Seems to be fine.
