problem solved
Old Aug 5, 2008 | 07:48 PM
114_ap2's Avatar
Default problem solved
a week ago my car died after i stopped to get some food, story goes like this
i have a new braille battery thats about 1 month old and i drive at least 60 miles everyday
drove about 5 miles from my house to i forgot where and the CEL turns on while i was on the freeway
i go to my friends shop and read the codes,
3 codes: both o2 sensor heater malfunction (something like that) and lean operation at WOT
i thought is was my test pipe
so i continue driving to go get food and turned off the car
get back in car and car won't start, i call aaa and get jumped, car starts right up
drive for 3 blocks and all hell breaks loose, eps light comes on abs light comes on, i loose power steering and then my dash lights start to flicker,
i pull over and get it towed to my friends shop
i tell him to replace the alternator cause i didn't think it was the battery
he replaces it with a honda reman alt
car starts up and is fine, alt is putting out 14.x and battery is good
i just picked up the car today and drive it home
THE SAME SH*T happens
HELP ME PLEASE!!!!!
Old Aug 5, 2008 | 07:51 PM
supahman04's Avatar
That may be a grounding issue. I had the same sort of thing happen in another car i owned (not an S) and it turned out that my main grounding strap to the engine got ripped off somehow.
Old Aug 6, 2008 | 07:44 AM
114_ap2's Avatar
thats supahman04, i checked that and its still good
N E One else??? please
Old Aug 6, 2008 | 09:58 AM
3ngin33r1's Avatar
Try a different battery.
Old Aug 6, 2008 | 01:19 PM
Code3S2k's Avatar
Could be a bad ground on the battery. Also check all the contections on the alternator and check the belt and the belt tensioner.
Old Aug 7, 2008 | 07:07 PM
supahman04's Avatar
Already put my .02 cents in. I still think a ground somewhere is the issue though.
Old Aug 7, 2008 | 07:14 PM
jeggy's Avatar
perform a voltage drop test across all connections. your mechanic should know how to do this.
Old Aug 8, 2008 | 09:13 AM
114_ap2's Avatar
found that problem, it was the o2 sensor wires shorting out the alternator fuse (ACC fuse), making alternator no work, thanks for all the help guys
Ziggyzacks2k
Mar 21, 2015 02:15 PM
SolidTypeSexy
17
Dec 28, 2012 06:20 PM
s2ke5
May 3, 2007 06:49 PM
PilotChris
Sep 28, 2003 05:57 PM
getchastuff
Apr 16, 2002 11:12 AM
