Problem with Vtec
Old Sep 14, 2005 | 04:45 AM
FastestS2K's Avatar
Unhappy Problem with Vtec
I know you have to let the motor warm up to 3 heat bars so thats not the problem. Sometimes when I crack on it Vtec dosent engauge. I think I am over due for an oil change so could that be the problem? My oil light came on for like 2 seconds then went off. Could that mess with the vtec? Please help.
Old Sep 14, 2005 | 04:50 AM
GoFaassttt's Avatar
Running low on oil could cause your problem. Check it right away. The owners manual does state to check your oil every time you fill up with gas. The car does consume oil at times.
Old Sep 14, 2005 | 07:17 AM
xviper's Avatar
By the time your oil light flickers during normal operations, you are DANGEROUSLY low on oil. You should really be checking your oil level frequently. If you do not, you will need to change your username to "SlowestS2K". (Not because your VTEC won't work but because your engine will be KAPUT!)
Old Sep 14, 2005 | 10:20 AM
steven975's Avatar
vtec works by having oil pressure press a pin that locks the roller-rockers together so both valves are on the high cam lobe. If there is not enough pressure it will not engage.
xviper is right, if the oil light ever comes on you have problems. Take care of your car!!!
Old Sep 14, 2005 | 11:02 AM
KAY'S's Avatar
yea honestly low oil well low enough to make yoru light come on is to low by well alot. and you even driving it like that is bad for the motor. you hitting vtec like (or trying) your motor is goingot be shot, just a matter of time now.... sorry man
Old Sep 14, 2005 | 02:31 PM
F20_C's Avatar
Dude, I have no idea what you just said.
Old Sep 14, 2005 | 03:48 PM
KAY'S's Avatar
lol sorry typing fast at work... long story short rebuild time..... atleast ina couple thousand miles
Old Sep 14, 2005 | 05:13 PM
VR4's Avatar
VR4
there goes another f20C down the tubes
Old Sep 14, 2005 | 05:59 PM
Jasonoff's Avatar
Banned
Did you check your vtec fluid level?
Old Sep 14, 2005 | 06:15 PM
joes sled 2000's Avatar
I have one in our shop for this very same reason and its getting a new engine.People CHECK YOURE OIL !!!!!!!!!
