Question about clutch delay valve
Old Nov 3, 2005 | 04:19 PM
K.Leland's Avatar
Default Question about clutch delay valve
I was wondering if anyone knew if the delay valve on the 2004 clutch affects the response when you depress the pedal or just when you let it out?
Old Nov 3, 2005 | 05:15 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Release only.
Old Nov 3, 2005 | 05:18 PM
CaveCricketnc's Avatar
K.Leland
The delay valve only works when you let out the clutch pedal to engage the clutch.
It has a one way valve that allows the full fluid flow to get into the slave cylinder when you depress the clutch to disengage it, but then when you let out on the pedal to engage the clutch the valve closes and restricts the fluid flow coming from the slave cylinder. If you have or can look at a service manual from 2004-2005 check out page 12-5. Hope this helps!
Old Nov 3, 2005 | 05:20 PM
sorry for the redundant reply...Billman types faster than me
Old Nov 4, 2005 | 03:54 AM
K.Leland's Avatar
Than answers the question. Much thanks
PooLeArMor
Jan 6, 2019 10:41 AM
macr88
Drivetrain
Mar 28, 2012 04:59 PM
shakes
Jun 11, 2007 02:40 PM
Marrk
Apr 27, 2007 03:07 PM
AEsco48
Mar 16, 2006 01:00 PM
