Question for AEM EMS Users
Old Aug 21, 2004 | 03:51 PM
bigpurp's Avatar
Default Question for AEM EMS Users
I feel my car is idling a little high (@ 1,700 rpm) with the EMS. What are you guys idling at?
Old Aug 21, 2004 | 04:00 PM
honda9krpm's Avatar
1000rpm when warm
1500rpm when cold
Old Aug 21, 2004 | 04:17 PM
wortham's Avatar
well, 1k is the norm for idle. mine starts out at about 1700 cold and works its way down. then again, i don't run anything but the stock pooter atm.
Old Aug 21, 2004 | 04:52 PM
kane.s2k's Avatar
1200-1300 rpm's on all the S2000's with the AEM EMS' I've come across
Old Aug 21, 2004 | 04:58 PM
Sideways's Avatar
I've set mine at 1400.
I haven't changed to the wide band yet and any less results in a pulsating idle because of the narrow band factory 02 sensor.
I doubt this has anything to do with yours but it's a heads up. Recently my idle went up a few hundred rpm. I discovered a vacuum hose had come off on the intake manifold. It was a noticeable change when it happened. Boost.
Old Aug 21, 2004 | 07:54 PM
yakrat's Avatar
My idle will not go any lower than 1100 with a/c on.
Old Aug 22, 2004 | 01:27 AM
f20kills's Avatar
I am at 700-1000 rpm when warm.
Idle's like stock.
Old Aug 22, 2004 | 02:03 AM
honda9krpm's Avatar
just curious, what are the ignition timing you guys have at idle?
I know that every car is differrent and it doesn't matter what this is as long as its at TDC but I am just curious. Mine is at 17.45 degree.
Old Aug 22, 2004 | 01:19 PM
yakrat's Avatar
Timing is set at 5.15 deg at idle. This is close to stock.
Old Aug 22, 2004 | 02:35 PM
syncer55's Avatar
Mine is around 1200 rpm
