quick ABS sensor question
Hey guys, sorry if this is a noob question but I did search a little before hand and didn't find it so anyway: I just bought a nice S2k from a very nice seller (who bought it from TB actually) who used to have bigger rims and coil overs on it. After he put it back to stock the ABS light was on. He had it scanned and was told that he needed to replace the abs sensor. Looking at it though, it all looks fine so I was just curious if you guys know what I should replace. I went to 1st Honda Parts to look for abs sensors and wasn't exactly sure which part I needed. I'm assuming I need the Speed Sensor right? Here is the link:
http://www.trademotion.com/partlocator/ind...playCatalogid=0
Any input is welcome...Thanks guys!
Edit: looked at your link and the "speed sensor" from that website is the correct ABS sensor.
You still have to find out which ABS sensor is broken. They should have been able to tell you.
Use Majestic Honda for excellent prices.
Each ABS sensor comes with a different bracket to mount properly. They just clip in and secure with a few 10mm (?) bolts. Easy DIY.
You might be able to find used ones from a part-out in our FS forum.
http://www.hondaautomotiveparts.com/auto/j...5=FRONT+KNUCKLE
Illustration # 21-22 for the front sensors.
