Quick electrical question
My 2004 S2K is throwing a P0108. While checking power to the MAP sensor I noticed the cable is reading 3.57V. The cable ground is showing 0.272 resistance. Are these normal values?
The video I watched on testing MAP sensors showed around 4.67V on the guy's S2K. Mine's quite a bit lower. My battery tests fine, though, around 12.5V. I topped it overnight to be sure and the cable reading is the same. Chassis grounds are tight but dirty. P0108 is the only code in the system.
Thanks for any insights!
AquilaEagle
Oct 23, 2019 03:50 AM
